iterate feature class does not recognize shapefiles
6666
15
04-29-2020 03:58 AM
DeanBeyer
I have a number of shapefiles (home range polygons) created in R.  In arcgis pro, I can reproject the shapefiles in batch just fine.  However, in model builder, when I use Iterate feature classes, the shapefiles are not recognized with the project tool.  The error code is:
000185: This data type is not supported
Other geoprocessing tools work just fine on these shapefiles in model builder.  #project error in iterate feature class
DavidPike
MVP Notable Contributor
I thought .shx was a mandatory file?
DeanBeyer
Sorry, you are correct, I missed it. The batch process files do include an .shx file.
Robert_LeClair
Esri Esteemed Contributor
Interesting.  Try this - use the Feature Class to Feature Class GP tool on 5 or 6 shapefiles.  Have the output from the GP tool go to another folder on disk.  Update the Model to point to the new folder and re-run.  Does the error message persist?
DeanBeyer
Well that beat it into submission! Thanks Robert!
JoshuaBixby
MVP Esteemed Contributor
Please mark a reply as Correct Answer or your question as Assumed Answered to close it out.
Robert_LeClair
Glad it worked out Dean - must be something amiss exporting to shapefile from R.  You could build the Feature Class to Feature Class GP tool process to the front of your model to automate things a bit more.  Happy ArcGIS Pro'ing!
