Once a Database View is created in ArcGIS Pro, how can I go back in and see the SQL that was used?
4648
5
04-22-2020 03:01 AM
TobiSellekaerts
I've successfully created a database view using ArcGIS Pro, using arcpy.CreateDatabaseView_management().  Now, I would like to see the SQL that was used in the creation of that view.  I could do this in ArcCatalog by right clicking on the view, Properties, Definition tab.  Is there a way to do this in ArcGIS Pro?  I tried both right click, properties and arcpy.Describe().  Since I still have ArcCatalog I've resorted to using that to view the SQL used to create the view, but am hoping I've just missed something in ArcGIS Pro.
Using:
ArcGIS Pro 2.4
ArcCatalog 10.7.1
JakeSkinner
Esri Esteemed Contributor
Hi Tobi,
Add the view to a map > right-click on the view > Properties > Source tab > click the pencil next to Query:
You should then see the SQL:
TobiSellekaerts
Fantastic - worked like a charm - many thanks!
Upon deeper inspection, this actually isn't returning the correct information.
In ArcCatalog, I see something like this:
CREATE VIEW ViewName AS SELECT OBJECTID, ATT2 AS NewAtt2, ATT3 AS NewAtt3, LEFT(SOMELONGATTRIBUTE, 40) AS NewShortAtt FROM Database.User.OriginalTable
which is what I'm looking for - the SQL which created the original view.
In ArcGIS Pro, I see something like this:
SELECT OBJECTID, NEWATT2, NEWATT3, NEWSHORTATT from Database.User.ViewName
which isn't what I'm looking for.
Apologies for not examining more closely before marking your reply as correct.
BruceHarold
Esri Frequent Contributor
Jake that's a query layer, output from Create Database View isn't showing the query for me.
TobiSellekaerts
Thanks Bruce and Jake for your responses.  I've opened a case with Esri Support and heard back that "there does not appear to be a way to do this in ArcGIS Pro currently like there is in ArcMap."  Support is lodging an enhancement request and at their request I've submitted a new idea to GeoNet:
ArcGIS Pro should allow you to see the SQL used to create a database view
I'm going to mark this question as answered, even though the answer is "You can't get there from here", and keep my fingers crossed for support in a future release.
BruceHarold
Great, I believe this has caught the attention of the right people in development so thanks for bringing this up.
