Issues with removing layers from Legend in ArcGIS Pro 3.6
1942
8
11-21-2025 12:26 PM
Teri_Dane
I recently installed Arc Pro 3.6 and noticed that when I remove layers from my legend in the Contents pane, they do not remain removed when I reopen my project. I do not want to individually turn off or change property settings for multiple layers that I permanently do not want in my legend. Is there a way to fix this, or is this a new bug with Pro 3.6?
2 Solutions
JeffMoulds
@Teri_Dane This is a bug that was introduced at 3.6. We are aiming to have this fixed in the first service pack, 3.6.1.
ShaneONeill_144
BUG-000181233: Removed legends in the layout reappear once the project is reopened in ArcGIS Pro 3.6. This defect is currently in review
ShaneONeill_144
Hi there, when using version 3.5 did you notice this behaviour? If not, this may be a bug as you have suggested. It would be worth reaching out to your local Esri distributor and have them test this for you to determine if it is a bug or not.
Teri_Dane
Hi @ShaneONeill_144 ,
This was not an issue with 3.5.x.
ShaneONeill_144
Thank you for your response! Please raise this with your local Esri Distributor and the Technical Support team can investigate this further for you
ShaneONeill_144
Teri_Dane
@ShaneONeill_144 Thank you for posting the BUG report. I did not get a chance to yesterday.
JeffMoulds
Teri_Dane
@JeffMoulds, Thank you. Do you know when the service pack will be available?
JeffMoulds
@Teri_Dane The schedule is still tentative at the moment, so I can't guarantee the release date. But we are aiming for mid to late December.
