Issues with Import Layout feature
786
06-25-2020 10:42 AM
KevinBurkman
Good day all. I am attempting to use the Insert>Import Layout option, which creates a pre-formatted layout with key elements (north arrow, scale bar, etc.). When I select the "Summary Letter Layout", it creates the layout with my map, however, it does not include any of the .shp features from my map. And if I right click on the layer in the Contents pane, I do not get an option to add data, the way I would if I had created a "standard" layout from the "New Layout" drop-down.
Am I correct in assuming that you cannot add data to these pre-formatted layouts?
Thank you,
Kevin
