Issues with Emerging Hot Spot Analysis variables
496
05-20-2026 08:09 AM
stc_analyst2018
Hello everyone,
I am currently having issues to understand the variables I get after executing the Emerging Hot Spot Analysis tool. They actually seem pretty different than what is indicated on the documentation : https://doc.esri.com/en/arcgis-pro/latest/tool-reference/space-time-pattern-mining/emerginghotspots....
First, correct me if I am wrong, but from what I've understood from a previous post (https://community.esri.com/t5/arcgis-pro-questions/question-about-emerging-hot-spot-analysis-results...), there are some variables present inside the summary table on the documentation page that are either included inside the 2D output feature (the "trend"  variables mostly), or either included inside the 3D STC after using "Vizualise STC in 3D" with the "Emerging Hot Spot results" option (z-score, p-value and bin value of the Gi* itself).
However, the names of my tables fields are not the same than the ones of the documentation :
OBJECTID
Time Step ID
Start Date
End Date
Time Step ID Exaggeration
Element
Location ID
VALUE_MEAN_ZEROS
Hot Spot Analysis z-score (VALUE_MEAN_ZEROS)
Hot Spot Analysis p-value (VALUE_MEAN_ZEROS)
Hot Spot Analysis bin (VALUE_MEAN_ZEROS)
Attribute table of the 3D layer
OBJECTID
Location ID
Category
Pattern Type VALUE_MEAN_ZEROS
Percent Significant Hot Spot
Percent Significant Cold Spot
Trend z-score VALUE_MEAN_ZEROS
Trend p-value VALUE_MEAN_ZEROS
Trend bin VALUE_MEAN_ZEROS
Sum VALUE_MEAN_ZEROS
Min VALUE_MEAN_ZEROS
Max VALUE_MEAN_ZEROS
Mean VALUE_MEAN_ZEROS
Standard Deviation VALUE_MEAN_ZEROS
Median VALUE_MEAN_ZEROS
Shape_Length
Shape_Area
Attribute table of the 2D layer.
I suppose that on the 3D layer, "Hot Spot Analysis z-score/p-value/bin value (VALUE_MEAN_ZEROS)" is the equivalent of "EMERGING_{ANALYSIS_VARIABLE}_HS_ZSCORE" on the documentation.
My main problem is with the 2D table. There are two "Trend" variables on the documentation ("{ANALYSIS_VARIABLE}_TREND_ZSCORE" / "EMERGING_{ANALYSIS_VARIABLE}_TREND_ZSCORE"). From what I understand, the first one calculates Mann-Kendall on the location's values (for example NDVI in my case) while the second one calculates M-K on location's Gi* values. In my 2D table, there is only one "trend" value, which is "Trend z-score/p-value/bin (VALUE_MEAN_ZEROS)". Then, I would like to know to which one of the two variables mentioned on the documentation this variable refers to.
Does anyone in Esri Spatial Statistics Team (@LynneBuie@LaurenGriffin) has an idea about what this "Trend z-score/p-value/bin (VALUE_MEAN_ZEROS)" refers to ? Or is there a problem with my software's version ? I precise that I have ArcGIS Pro latest version (3.7. while I'm writing this post).
Thank you very much for your eventual responses and sorry for my bad english.
