Issues using generate points along line tool in arcpy, HELP.
1118
11-14-2024 09:45 AM
LukeStork
I am trying to use arcpy to shorten my workflow. I am attempting to use the tool to place one point every 100 meters along the line, I have done this manually using the tool many times but when I try to use the tool in arcpy I keep receiving the same error message.
ERROR 000628: Cannot set input into parameter Percentage.
 Most suggestions I found said to make sure the spatial reference was in meters which I verified:
Spatial Reference: WGS_1984_Web_Mercator_Auxiliary_Sphere
Units of input: Meter
I am confused that the tool is working manually but not in my script, any tips? Help would be greatly appreciated.
DrewDowling
Can you post your code?
LukeStork
I ended up just avoiding the points along the lines tool altogether to avoid this problem and ended up with something functional. Thanks for your reply anyway Drew!
