Issues Exporting Map Using ArcGIS Pro Through VMWare on a Mac
1019
05-03-2023 03:02 PM
BriannaCahill
I am having issues exporting maps while running ArcGIS Pro in VMWare on my macbook. I am able to access ArcGIS Project Files without a problem, but exporting never works. Everytime I try exporting (no matter the file type), it says "Export Complete;" however, I am unable to open the file. Is this a problem others have had and if so, what is your workaround?
DanPatterson
MVP Esteemed Contributor
You went through the requirements for Pro as listed here
Run ArcGIS Pro on a Mac—ArcGIS Pro | Documentation
and as the topic indicates, anything outside of that, Tech Support would be your best source.
... sort of retired...
