Issues- Export Training Datasets for Binary Segmentation of Deep Learning
761
06-21-2022 11:54 PM
ANKITAMITRA
Could you please help me understand for binary semantic segmentation, will I select “Classified Tiles” under Metadata format while using the Export Training Data tool for DL”? I am a bit confused on that whether to select the option of Classified Tiles or Labelled Tiles?
Currently, I started to run this tool using Classified Tiles option, in the output folder under label subfolder which has been created I do NOT see that it has been generated as a black and white background, which is required for the DL model i.e., white(areas to be detected),black(rest of the areas). I do not see such a visualization. Instead I see in a different color (an example is attached in the files for one of the image chips generated), when I am reading the generated output image and corresponding labelled file in R.
Please could you help me with this. Is this how the format should generally be executed?
The third issue is when I am trying to select input mask, the program is not running successfully. The previous files have been generated without selecting any input mask.
I am new to ArcGIS Pro. Would appreciate help and suggestions.
Many Thanks,
