Issue with Pop-ups Not Displaying for Specific Layers (ArcGIS Pro)
1917
09-16-2024 07:20 AM
GrizzlyBear
I’m experiencing an issue where there is a lag in displaying pop-ups, even though they have been enabled. I receive the message: "Pop-ups are disabled for this layer," even though pop-ups are correctly configured (see screenshot above).
The pop-ups eventually displays but takes a few seconds, which is unusual.
This problem only seems to affect a particular group of layers—other layers in the same map are functioning properly, with pop-ups displaying as expected.
Has anyone encountered this before or know why this might be happening?
Robert_LeClair
Esri Esteemed Contributor
What type of layers are experiencing the pop-up issue?  Shapefile?  File geodatabase?  Web layers?
GrizzlyBear
Feature classes within an ArcGIS project (File geodatabase)
Robert_LeClair
Okay - thanks.  Next question - is the layer in a group layer by chance?  If so, then you need to enable popups for the group layer.
GrizzlyBear
I appreciate your response. @Robert_LeClair , correct me if I am wrong but in ArcGIS Pro, you cannot directly enable pop-ups for a group layer because pop-ups are managed at the individual layer level. I can only enable pop-ups for each individual layer within the group, as far as I am aware. Apologies, If I misread your response.
