issue with deleteItem(map)
1663
12-05-2024 01:16 AM
DavideBollo
Hi everyone, i created a simple map switcher in python and I put it in a toolbox script.
the script receives as input:
  1. aprx project;
  2. map name to be deleted (from aprx project);
  3. input mapx with the new map;
  4. pagx exporting checkbox;
  5. exported pagx path.
The script performs the following operations:
  1. Project backup;
  2. Deleting target map;
  3. Loading new map;
  4. Renaming new map as deleted one;
  5. Optionally export layout as pagx file with new map.
If executed in "stand alone" from windows shell, the script works perfectly but, if inserted in a toolbox script, launched from ArcGIS (in a blank project) the execution remains stuck at the deleteItem command.
Why? I can't find any reason.
Somebody can help? (script and validation attached).
Thank you in advance.
Tested with ArcGIS Pro 3.3.1 and 3.4
Windows 10 Pro for Workstation
22H2 build 19045.4894
jameslogan5
Seeing a similar issue in a Python script tool run from Toolbox. Trying to programmatically remove extraneous map objects from the workspace before the script completes. Did you find a solution?
DavideBollo
what do you mean with "extraneous map objects"?
no solution right now...
DavideBollo
update...
I tried deleting all the layers and then deleting the map...the result still the same: my process gets stuck on "deleteMap"...
ITDivision
The same applies to version 3.6.2. Is there a solution or alternative that doesn't involve running a separate script?
