Issue while publishing feature layer to Enterprise.
1237
03-28-2024 04:40 AM
AbhyanshuGupta
I am trying to publish a set of feature layer from my ArcGIS Pro to my Enterprise account. I am using the Share as WebLayer tool. When i am trying to publish the layer, it is getting failed and i am getting the following error messages:
siteadmin 2024-03-28 16:59:04 Status: InProgress StatusMessage: Publishing tool initialized
Map_POI_WFL 40 WebFeatureLayer ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ siteadmin 2024-03-28 16:59:04 Status: InProgress StatusMessage: Publishing web layer (AGO)
Map_POI_WFL 40 WebFeatureLayer ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ siteadmin 2024-03-28 17:01:47 Status: InProgress StatusMessage: ERROR 001369: Failed to create the service. Failed to execute (PublishServiceDefinition). ERROR 001369: Failed to create the service. Failed to execute (PublishServiceDefinition). Failed to execute (Publish Portal Service). Failed.
Map_POI_WFL 40 WebFeatureLayer ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ siteadmin 2024-03-28 17:01:54 Status: InProgress StatusMessage: Publishing web layer failed (AGO)
Map_POI_WFL 40 WebFeatureLayer ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ siteadmin 2024-03-28 17:01:56 Status: InProgress StatusMessage: Server Response: {"error":{"code":404,"message":"Service Hosted/Map_POI_WFL/MapServer not found ","details":[]}}
Map_POI_WFL 40 WebFeatureLayer ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ siteadmin 2024-03-28 17:01:58 Status: InProgress StatusMessage: Server Response: ERROR: code:404, Service Hosted/Map_POI_WFL/MapServer not found , No resource could be found at that address.
Map_POI_WFL 40 WebFeatureLayer ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ siteadmin 2024-03-28 17:02:00 Status: InProgress StatusMessage: Publishing tool execution failed
Map_POI_WFL 40 WebFeatureLayer ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ siteadmin 2024-03-28 17:02:02 Status: Failed ErrorMessage: Failed to publish web layer
Why am i facing this error, how can i resolve this and publish my layers. Am i supposed to change any setting while publishing?
Regards,
Abhyanshu Gupta
ChrisUnderwood
Hello @AbhyanshuGupta , there are some suggestions about the error 001369 here.
https://support.esri.com/en-us/knowledge-base/error-error-001369-failed-to-create-the-service-000016...
If those do not help, please can you give a bit more information about your system, ArcGIS versions & data sources etc
