Issue while Publishing Extract Data Task as geoprocessing service with ArcGIS Pro 3.2.2 and ArcGIS server 11.1
826
10-03-2024 12:23 PM
Labels (2)
SreejithSreenivasan
1) Getting following error while publishing "Extract Data Task" as geoprocessing service(output feature format is dwg file ) using ArcGIS Pro 3.2.2 and ArcGIS server 11.1.What may be the reason?
"Status: Failed  ErrorMessage: ERROR 001249: Cannot package result Extract Data Task because of errors in the result."
2.After executing the "Extract Data Task" , cad.dwg.xml  file also gets generated along with the dwg file . Is there any option to exclude the cad.dwg.xml file from the outzip folder?
