Is Split in ArcGIS Pro the same as the Cut Polygon Tool in ArcMap?
8366
10
10-29-2019 03:37 PM
EvanDowdakin1
I am slowly moving some of my organization's digitizing projects to Pro as a way to familiarize myself with the new software. However, I can't seem to simply cut a polygon in half using the "Split" tool like I could in ArcMap with the Cut Polygon tool. It spits out the following error "Split failed. New geometry must intersect polylines and intersect polygons in two or more places." What is the point of the Split tool if you can't split/cut a single polygon in half?
MichaelCairns
Great, thanks Scott
