Is it possible to disallow a null attribute with contingent attribute rules?
1283
12-13-2022 12:12 PM
LLCCG
I have a feature class that has an attribute called "status", and another attribute called "approved by". Obviously, when something is in the planning stage, I want "approved by" to remain null. But when the status changes to "approved", I want to require some value in "approved by".
I don't care what the user puts in that space--there are too many possibilities to create a list of domains. But I do want to require that something is put there.
Using contingent values, I can require that the "Approved by" value is <ANY> when "Status" changes to approved. But a null value seems to pass the <ANY> test.
Is there any way to require a value in "Approved by" if and only if "Status" is set to "Approved"?
Tags (1)
by Anonymous User
Not applicable
You should be able to build an attribute rule for this. Constraint attribute rules—ArcGIS Pro | Documentation
Something like this might would work:
// constraint rule for a field that is non-nullable
// Triggers: Insert, Update
if($feature.status == "Approved") && IsEmpty($feature.ApprovedBy){return false}
return true
