Is it possible to create a new group layer with arcpy?
12067
6
06-15-2021 01:31 PM
JesseTemplin2
I am trying to add group layers to a map with ArcPy. I have seen old answers saying this is not possible, and suggesting instead to create a layer file with the groups already created. This will not work for me because the number of groups is not known in advance.
Is it possible to add group layers to a map in ArcPy?
JohannesLindner
MVP Alum
For ArcGIS Pro:
Create an empty group layer and save it, then run this:
empty_group_layer_file = arcpy.mp.LayerFile(r"H:\New Group Layer.lyrx")
active_map = arcpy.mp.ArcGISProject("current").activeMap
# In this example, I'll use a dict of {group_layer_name: [layers]} as input. Adjust according to your existing code.
group_layers = {
    "Group Layer 1": [layer_1, layer_2],
    "Group Layer 2": [layer_3, layer_4],
for group_name, layers in group_layers.items():
    group = active_map.addLayer(empty_group_layer_file)[0]
    group.name = group_name
    for lyr in layers:
        active_map.addLayerToGroup(group, lyr)
Have a great day!
Johannes
JohannesLindner
MVP Alum
For ArcGIS Pro:
group_layers = {
    for lyr in layers:
Have a great day!
Johannes
JesseTemplin2
Thanks Johannes! After fixing a couple typos (AddLayer -> addLayer) I was able to use this to create new group layers.
mTylerH
this works in ArcMap too if you do the same but with an empty group .lyr file and make the appropriate changes to work in arcpy.mapping instead of arcpy.mp
Brian_Wilson
Honored Contributor
After I got past the mental block of using Pro to create an empty LYRX file, this works. I was expecting line one to create the file for me. Thanks!
GISDataTasPorts
This is much simpler for recent versions of ArcGIS Pro (as it always should have been).  You can now create a new empty group layer with a single arcpy line like this:
new_group_layer = mp.createGroupLayer("New Group Layer")
For more details, see the 'Map' class documentation at: Map—ArcGIS Pro | Documentation
(search on the page for 'creategrouplayer')
mTylerH
lovely
