Is is possible to set attribute mapping with chart symbology in ArcGIS Pro?
1463
07-27-2020 03:28 PM
JosephPoncy
I would like to display field values in a map using chart symbology. Is this possible?
I can accomplish what I want while using single point symbology by enabling symbol property connections and setting attribute mapping to a custom expression.
However, if I use this same method with charts symbology, the custom expression is ignored and it reverts to the default value. I've tested setting other attribute mapping options with the chart symbology as well. Every attribute mapping option I try is ignored, whether it is size, color or string.
It seems that attribute mapping is broken for chart symbology.
chart symbology‌ attribute mapping‌ arcgis-pro-2.5
