Is Arcade enabled in the Popup Configuration Window?
1104
03-06-2019 03:17 PM
JohnManson2
Running the latest version of ArcGIS Pro.  newbe here.  The online help says that it is possible to format field values in the POpup Configuration window, it says that on the bottom of the field editing window, you have options to Disable Popups, Configure Acrade Expressions, or reset.  On my system, I only have Disable and reset buttons on the bottom, nothing about Arcade.  Does something need to be configured to enable the use of arcade in popups?  Just looking to clean up the formatting of some of the numbers, such as currency, sig figs, etc.
John Manson
Tags (1)
JayJohnsonWashoeCounty
In #arcgis pro 2.3 patch 1, you can use Arcade expressions, via the Feature Layer, Labeling, Label Class pane.Pro Arcade Lableing
Not sure what "Disable and reset buttons" you are referring to.
Jay
Washoe County GIS
JohnManson2
Sorry Jay I had an older version of Pro, that's why I had no arcade functionality.  The updated version had a button for using arcade in the popup by creating custom field expressions, which allows for formatting. Looks great in Pro. Unfortunately, it doesn't look like explorer for IOS, latest version, supports the custom expressions, at least not yet, they display as blanks.
