Inverting aerial masking
1045
03-24-2022 11:29 AM
ChetHugo
I have a aerial image that contains gray areas that I would like to mask.
I created a polygon for a mask but it masks the area that I need and not the two areas that I do not want.  How do I invert the area to be masked?  If there were not two areas to remove I would simply use a polygon around the gray area.
mneer
Please forgive me if I'm off here - but I believe if its just a single image you can merely import the image into a image mosaic dataset and merely adjust the footprint boundary.   Thus limiting the image to the footprint boundary.
