Installing Pro 3.5
6309
7
08-23-2025 03:52 PM
DavidGray1
Hi; I see that there are numerous posts regarding installing Pro 3.X. and none of them describes with any clarity a working solution. I get the same cryptic message about some .NET thing being needed. After following various unexplained prompts and chasing useless rabbit holes of acronyms and cryptic language links and spending hours in frustration, I have no upgrade installed. This is ridiculous and it used to be easy! Offhand, it looks like AI got involved to make our lives faster and seamless.   Dave      ESRI should provide a simple step by step set of instructions in simple real everyday language on how to do this.....at least 3,2 still works!.....So far.
DavidGray1
Dan and all: Yep; had to get with tech Support to get it straightened out. Turns out single user Basic doesn't need the number - why couldn't they have just said so instead of unresponsive grayed out response boxes? And why did it have to remove all taskbar icons just because? But I am up and running again. call it a solution!
Dave
DanPatterson
MVP Esteemed Contributor
ArcGIS Pro 3.5 system requirements—ArcGIS Pro | Documentation
this section
Software requirements
install these, if you already have it, it won't be needed to install
Download .NET 8.0 (Linux, macOS, and Windows) | .NET
Microsoft Edge WebView2 | Microsoft Edge Developer
Then, depending on whether it is a single install (eg you have full control over your environment)
Download ArcGIS Pro—ArcGIS Pro | Documentation
Did you try to follow those instructions?
... sort of retired...
DavidGray1
Thanks Dan; As usual you are a big help. I now have 3.5 installed, but I can't use it. Installing .net 8.0 rather than 9.0 seems to have made a difference.The authorization process doesn't like my authorization number (which I obtained from my profile on myesri)and the (next) button remains grayed out and I can't get anywhere for online authorization. It's always something. I am a single commercial use license.   Dave
DanPatterson
David
Sadly to say, if you can't get the authorization number recognized, then you will have to contact Tech Support.
Fortunately your software is now good.  Pro requires a specific Net version for its release, installing one above or below doesn't cover or compensate for the requirements.
Good luck getting the authorization straightened out.
DavidGray1
Dave
RClavero
Hello @DavidGray1, we don't know which error/warning message you are exactly seeing, but if ArcGIS Pro keeps asking for the .NET Desktop Runtime, check this article: https://support.esri.com/en-us/knowledge-base/error-arcgis-pro-requires-microsoft-net-desktop-runtim...
The .NET Desktop Runtime 8.0.19 (the current last version available*) should work well and allow you to install ArcGIS Pro 3.5.
*https://dotnet.microsoft.com/en-us/download/dotnet/8.0
RichardDaniels
MVP Regular Contributor
key here being, .NET Desktop Runtime version 8.0.19 or higher within the v8 family. Each .Net major version change is a breaking change for ArcGIS Pro.
BarryNorthey
FAQ article ArcGIS Pro and .NET Life Cycle Overlap and Release Cadence might explain a bit about Microsoft .net versions and esri. Some problems attributed to esri are due to changes by Microsoft. The loss of the personal geodatabase is a case in point.
You implied that you were using Pro 3.2. Excerpt: ArcGIS Pro versions 3.0 through 3.2 require .NET 6 to run, and this requirement will not change. I recall people reporting 3.0-2 installation problems who were installing just .net 8x runtime and assuming it would work, which it did not. They had to install .net 6x. You can have more than one .net version installed but must have the correct one(s) for the version of Pro you are using.
