Install Python Packages through python package manager in arcgis pro
9867
14
09-10-2018 04:58 PM
ManishShrivastav
When I try to install python packages like 'spyder' through the package manager in arcgis pro 2.2.2, it doesn't allow me to do so. The install button is greyed out. Any help?
DanPatterson_Retired
From esri's end? No
From my end?  My students are installing packages with no incident on their machines using conda.
If you want to see a revision list you can use
(arcgispro-py3) C:\ArcGISPro\bin\Python\envs\arcgispro-py3>conda list --revisions
2018-10-03 17:02:36  (rev 😎
     arcgispro  {2.2 (esri) -> 2.3 (esri)}
     mkl  {2018.0.3 -> 2018.0.3 (esri)}
     netcdf4  {1.4.1 -> 1.4.1 (esri)}
    +pkg-metadata-0.4.6 (esri)
or if you want to test an install without actually installing it you can use
conda install --dry-run
For example, if you want to update a package that you currently can't because the package manager is disabled you can use.
(arcgispro-py3) C:\ArcGISPro\bin\Python\envs\arcgispro-py3>conda update scipy --dry-run
Fetching package metadata ...............
Solving package specifications: .
Package plan for installation in environment C:\ArcGISPro\bin\Python\envs\arcgispro-py3:
The following packages will be UPDATED:
    scipy: 1.1.0-py36h672f292_0 --> 1.1.0-py36h4f6bf74_1
Happy non-cloning
MatthewDriscoll
Thank you Dan, I will give it a go!
Perhaps making conda  less onerous will help
/blogs/dan_patterson/2018/10/08/making-conda-package-installs-easier
MattDeitemeyer
Just updated to 2.2.4 and the Python Package Manger > Add Packages > install button is still grayed out. I'm using workarounds to get by, but this bug has held on for three or four releases. When will this get fixed?
