Install PRO with 'Enable Undo toggled on by default' checked
1459
10-21-2022 10:34 AM
MattDeitemeyer
Is there anyway to install PRO with the 'Enable Undo toggled on by default' checked. By default the check box is unchecked. The check box is in Settings -> Options -> Application -> Geoprocessing. We deploy PRO to users with a larger install package which includes 'hacking' some Registry settings. Is it possible to change the 'Enable Undo toggled on by default' to checked in the Registry? If yes, what is the setting name and value?
I'm open to other ideas to automate this task.
DrewFlater
It is not possible to set it using the Registry. In a near term release (likely 3.2) you will be able to configure this setting during a configured administrative install, using the approach described here: https://pro.arcgis.com/en/pro-app/latest/get-started/application-setting-management.htm
DrewFlater
