Install ArcGis Pro 3.3 | Intune/SCCM | Webview2 runtime failure
2456
11-25-2024 02:19 PM
C0LDW1R3D
Running into a very difficult problem and I’m not sure how to proceed.
We deploy Applications via SCCM/Intune.
This most recent update to ArcGIS Pro where they have moved for Webview2 Runtime, is causing some very strange deployment inconsistencies.
I've done a lot of testing of deployments, so I'll try to keep it brief.
  1. Set deployment of ArcGIS Pro using PSADT and deployed via Intune as System (Cause who allows users installs). On my test computers, Virtual and physical, (1 Virtual Machine, and 3 Physical Machines | Virtual was Fresh no prior Installations - installed correctly | 1 Physical - Fresh install, installed fine | 2nd Physical was an upgrade from 3.1.4 to check if it updates fine) all my tests were fine, start production deployment. On a small subsample of test production computers, it fails - and I get:
ArcGIS Pro requires Microsoft Edge WebView2 Runtime (x64). To download and install Microsoft Edge WebView2 Evergreen Runtime, visit the Microsoft website or contact your system administrator. To install ArcGIS Pro for All Users (per-machine), you must also install WebView2 Runtime as per-machine. To do this, right-click the WebView2 installer and click Run as administrator.
So, I do this, downloaded the program from Microsoft Edge WebView2 | Microsoft Edge Developer and run as admin and install on that computer. Try installation again from Intune, failed.
2. I deploy ArcGIS Pro without using PSADT using a setup.cmd file that contains.
msiexec.exe /i "ArcGISPro.msi" /qn ALLUSERS=1 ENABLEEUEI=0 ACCEPTEULA=YES AUTHORIZATION_TYPE=CONCURRENT_USE ESRI_LICENSE_HOST=@PRDARCDSLM01 REBOOT=ReallySuppress
Same error as before.
3. Intune Install command (instead of referencing setup.cmd)
still fails.
4. Install ArcPro msi Locally - Success - Not Viable as we have around 150 workstations that require this.
5. Use PSADT to move the files to temp c drive location, then Intune install script to run the local setup.cmd file I moved over with the msi files.
Still Fails.
I tried step 3 using SCCM as well, and I get the same WebView runtime error whenever I try and install from Intune/SCCM.
I tried a few more test prod machines, all failed with this Error, when doing it from intune/sccm. so, i expect I need to overcome this problem, as i foresee it being a bigger issue, when pushing the update to the wider org.
Before you ask, the computer that is exhibiting this error, does have this key (WebView runtime key) its in local machine, meaning it's a per machine install.
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\EdgeUpdate\Clients\{F3017226-FE2A-4295-8BDF-00C3A9A7E4C5}
with pv = 130.0.2849.80
So it's a strange problem i am having, and I don't know how to get past this, any and all ideas are welcome at this stage, ESRI won't help as they 2; don't support install of ARC from third party application management systems; they should definitely be supporting Intune/SCCMas they are the gold standard, but also after further push, have not seen this error before, or can provide any more help then providing these 2 links.
https://www.esri.com/arcgis-blog/products/arcgis-pro/administration/arcgis-pro-3-3-requires-webview2...
How to deploying ArcGIS Pro 3.2 in Microsoft Intun... - Esri Community
