Inserting features at absolute height
2077
06-23-2017 06:35 AM
ChristophStöckerl2
I'm trying to publish 3D object layers for features that were converted from an IFC file to multipatch layers. Those features need to be at an absolute height instead of relative to the ground. My problem is, that when I'm inserting those multipatch layers into my document they are always inserted at about 400 meters below the ground. Of course I can move those layers vertically until they are above the ground, but doing this for a bunch of layers is kind of tedious.
Is there a better way to place those layers at absolute height? Perhaps a tool, that uses the default elevation surface of ArcGIS Pro? Any help would be appreciated.
JakeSkinner
Esri Esteemed Contributor
Hi Christoph,
Try the Adjust 3D Z tool.  This will allow you to adjust the height of the multipatch.
JakeSkinner
Hi Christoph,
