Inputting E00 file to ArcGIS Pro
1047
6
10-31-2025 12:42 AM
gisuser12
Previously, to input E00 file to ArcMap, "Import from E00" tool, then "Feature Class to Feature Class" tool was used.
To input E00 file to ArcGIS Pro, "Quick Import" tool was used. However, there is error "Esri Geodatabase Writer: Feature Type Definition "xyz" was requested, but not defined. Please visit https://www.safe.com/support". Although arc feature could be displayed on Pro, point and polygon features appear missing.
Spatial ETL tool (to convert E00 to shp) and Feature Class to Geodatabase tool were then used. This time, arc, point, and polygon feature are present. However, there appears to be missing fields ( in the attribute table. "Polygonid", “Scale” and “Angle” attribute fields are missing when using the Spatial ETL tool.
Any leads on how to input E00 to Pro and how to preserve all attributes would be appreciated
DanPatterson
MVP Esteemed Contributor
Supported formats with the Data Interoperability extension—ArcGIS Pro | Documentation
is recommended unless you have access to ArcMap or the often recommended conversion utility or other GIS software
... sort of retired...
gisuser12
@DanPatterson
Indeed, E00 is listed as one of the supported formats. Given that ArcMap is going to be retired, the user would like to implement a ArcGIS Pro workflow and that the data would match 100%...
DanPatterson
They would need the Data Interoperability extension then if they want to keep within the ArcGIS Pro environment.  All other suggestions involve working outside it.  Conversion of existing e00 files to a geodatabase would be necessary if they want to continue to use that data
Priya_Das
Hi @gisuser12
ArcGIS Pro does not natively support importing E00 files. To work with E00 data in ArcGIS Pro, you’ll need to convert it using alternative methods.
Import an ArcInfo interchange file (E00) in ArcGIS: https://support.esri.com/en-us/knowledge-base/how-to-import-an-arcinfo-interchange-file-e00-in-arcgi...
gisuser12
Hi @Priya_Das
There is no issue with using Import from E00 and Feature Class to Feature Class tool using ArcMap.
However, there is no luck in using the Quick Import tool (missing feature and error in tool) and Spatial ETL tool (feature missing attribute fields) on ArcGIS Pro. Since ArcMap will retire next year, the user would like to find a workflow to input E00 to ArcGIS Pro.
Priya_Das
Hi @gisuser12
You can raise this with Esri technical support for this issue.
