Inline variable after select layer by attribute
1332
04-09-2025 12:20 AM
CharelvanDijk
Dear all,
I would like to use the name of a selected municipality (the field is called statnaam) as an inline variable, so that the name is taken into account in the map layer from an intersect. See attachment. Unfortunately, I can't get it to work. Does anyone have a suggestion?
BrendanNewell
Hi @CharelvanDijk, you can use the Get Field Value tool to generate the field value that can then be used as a inline variable.
You want to have the your updated layer output as the input into the get field value tool.
BrendanNewell
CharelvanDijk
Thank you, Brendan. I used the wrong tool, but with your suggestion it worked right away. Awesome.
