Infographics question
1841
08-31-2017 02:12 PM
DEAF_PROBERT_68
Honored Contributor
I am doing some reading and do some exercises in ArcGIS Pro. I have a question about Infographics. So when I click on the Infographics button in the Map Tab and in the Inquiry group. It is now blue depress and how do I clear it and return back to select arrow tool ?
Using the eBook Learning ArcGIS Pro on page 38 and talks about Infographics so that is where I am asking aboutl.
DanPatterson_Retired
tools normally remain selected until another one is selected... don't have the book so screen grabs are useful
AdrianWelsh
MVP Honored Contributor
I agree, screenshots are the way to go. I'd be curious to see what the book says.
DEAF_PROBERT_68
Honored Contributor
Actually I figured it out. It is very simple. You just go over to the Explore tool bar and it disappeared and then you are back into computer mouse select tool again.. Remember it is almost the same thing with ArcMap.
DEAF_PROBERT_68
Honored Contributor
like I said, tools/buttons etc remain selected until you select a new one... there are some that you have to select each time you want to use it... you will discover these in Pro as well, so don't be surprised when you encounter this behaviour.
