Incompatible Pro and Server versions 00256: Server version <value> tool <value> does not have new parameter
1230
03-24-2024 09:13 PM
TKPAdmin
Hi, I'm running into the the issue where my Pro version is no longer compatible with Server whilst trying to  publish a print service. Pro is expecting a parameter that doesn't exist in Server.
We won't be upgrading Server anytime soon so can I download a previous version of Pro from somewhere?
Or can I remove the Layout ItemID, Report Template and Report Item ID parameters when publishing?
ShaneONeill_144
Hi there,
You should be able to download earlier versions of ArcGIS Pro from the 'Downloads' section of MyEsri.
Just make sure you download the appropriate version for your version of ArcGIS Enterprise.
ShaneONeill_144
Hi there,
