Including labels with clustered features
2557
05-08-2024 04:15 PM
davedoesgis
I have an ArcGIS Pro map layer that has labels turned on. I've also turned on aggregation with clustering. At my map scale, I don't expect to have more than 3-5 features clustered. The clustering feature is great, except I lose my labels!
I'd like to keep my map labels. Ideally, a cluster could have a single label that stacks the clustered features in a bulleted list or something like that. Is there any way to do that?
BAD SOLUTION: I guess I could turn off clustering, create anno for the layer, and then turn the clustering back on. This would create multiple labels (anno) for the clustered point. I guess this is better than what I have now, but I'd prefer the cluster to have a single label. Also, like anything involving anno, you have to redo it whenever your dataset changes or you change the map scale, so it's not ideal.
POSSIBLE SOLUTION: I see the cluster label (where it says "3" in my screenshot) can come from an Arcade expression. Anyone know how to access the features and field values in the clustered points? That might do the trick.
If it seems like I'm grasping at straws, you're right. Anybody solve this problem without manually labeling your clusters?
EMagnuson
We've been running into this same limitation. If you right click on the clusters in the contents pane and go to properties, you can add more fields to the clusters. But the issue is that the only aggregation function Pro allows for categorical data is "Mode", making this functionality pretty much useless for labelling. I would LOVE the ability to use "concatenate" so my clusters would include the names of each of the features they're grouping, but alas.
