In the background of model builder workflow
1282
05-03-2022 02:17 AM
barrylim
Is there a way to see what exactly happened in the background of a modelbuilder workflow? For example, what SQL commands were executed in the geodatabase?
DanPatterson
MVP Esteemed Contributor
export the model to a script and examine its contents
... sort of retired...
barrylim
Thank you for your fast reply. If I export the model, I get the python script, but what if I want to see the SQL-Code because I  ArcGIS works with a geodatabase?
Thx in advance!
DanPatterson
if sql was used by portions of the model it will show it, otherwise it won't
