Importing data
1014
09-03-2021 01:32 AM
GIS_Ecologist
Good morning,
I am have two problems that I need to work out. The first is that I need to import multiple tables from m Different excel spreadsheets. I would like to work out a automatic way to importing a specific folder contain up to 40 excel spreadsheets and specifically target a table within those spreadsheets to import.
The second problem is that when experimenting with importing the tables I notice there are null entries generating and I see no reason why they are. Is there a tool I can use for scrapping null entries in multiple tables? The first entry is the only one I need and it is importing correctly, with all fields generating correctly.
Thanks very much, if there is any other information you may need let me know.
Tags (1)
mdonnelly
If it were me I would code up some Python to automate the importation from a number of different spreadsheets.
You use the os library to list files in your folder/s and then work through each one, passing each one to the arcpy.ExcelToTable_conversion function.
As for your nulls, there could be spaces in your Excel document. Use Find/Replace in Excel. In the Find box, type a space. In the Replace box, don't type anything. Press "Replace All."
Regards,
Mark
