Import Label Expression bug Pro 2.8.1
1722
11-28-2021 04:39 PM
LeandraGordon
Hi - does anyone know if this little bug importing label expression files has been fixed - if so which version:
(The label expression works fine if I copy and paste from notepad).
Just wanting to save some time logging a bug through my org.
Tags (1)
DanPatterson
MVP Esteemed Contributor
Without a bug number, one is left scrolling through
arcgis-pro-29x-issues-addressed (esri.com)
or for previous versions
Release notes for ArcGIS Pro 2.8—ArcGIS Pro | Documentation
or searching using keywords on
Esri Support | ArcGIS Technical Support
Have you tried python rather than Arcade?
... sort of retired...
LeandraGordon
You are right Dan - just wondered if anybody knew off the top of their head as it's a bit of a pain getting a bug lodged and they might have fixed it in later versions.
Same problem occurs regardless of the language and cut and paste works fine.
Looks like it occurs everywhere 'import expression' is used:
DanPatterson
If cut and paste from a pure text editor works, there must be some formatting/codepage issue that isn't liked.
A little nudge/reminder if you have a case open might be prudent.
