Import arcmap projects into arcgis pro
573
02-22-2026 09:46 AM
Srinivasraoboina
How to import arcmap mxd files into arcgis pro without loss of any map properties etc...
2 Solutions
VenkataKondepati
Honored Contributor
Hi @Srinivasraoboina,
There is a documentation with step by step instructions for migrating MXD files to ArcGIS Pro.
Tutorial: Import an ArcMap document—ArcGIS Pro | Documentation
Migrate from ArcMap to ArcGIS Pro | Documentation
They should provide you instructions and let me know if you have further questions.
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
Srinivasraoboina
Thanks for the help this works
VenkataKondepati
Honored Contributor
Regards,
Venkat
Srinivasraoboina
