Identify function not returning attribute values
855
01-31-2025 07:47 AM
PaulWilliamGagnon
Hello, I am having an issue with the identify function in ARCGIS Pro, for a certain .shp data layer. When I click on the map to identify a feature in the data layer, in the popup instead of getting a list of attribute values I get a replication of the attribute column name with a period between, i.e. "Attribute_X.Attribute_X". I imagine there is some setting related to these attributes that I need to tweak, but for the life of me have no idea what it is. See the attached screenshot. There are no active joins or relates.
Robert_LeClair
Esri Esteemed Contributor
That's pretty interesting and frustrating at the same time.  Would you be able to share a sample of the data with me so I may test it on my side?  My email address is rleclair at esri dot com - thanks!
