I'm getting this message with I try to add a shape file to a map, "Failed to add data, unsupported data type."
14765
13
05-20-2018 06:40 PM
DarrinNielsen
The shape file was created in QGIS. It is is clean file with no reported errors according to diagnostic tools in QGIS. But, when I attempt to load to a map in ArcGIS pro, the above error message appears. At a loss as to what else to try.
AdrianWelsh
MVP Honored Contributor
Darrin,
Make sure that the folder containing the shapefile contains all of the related files (like .shp, .shx, .dbf, .prj, .sbn, .cpg, etc.).
DarrinNielsen
Thank you Adrian. Yes, I have included those files. The odd thing is that I was able to add one particular shapefile to the map (an earlier version of the file I am most interested in adding) which was also generated from QGIS so this is very perplexing to me and difficult to troubleshoot.
DanPatterson_Retired
When you say 'load a map' do you mean 'add the shapefile to a map' ?
DarrinNielsen
Yes. Thank you.
You can try a Check Geometry from with ArcGIS PRO or the standalone application shapechecker
https://community.esri.com/thread/177037
if there is no substantive error, go back to qgis and export another copy... it could just be a bad copy
DarrinNielsen
Thank you Dan. I'll give it a try.
DarrinNielsen
I have found a difference between the old version of the shapefile that does add to the map and the version that I need to add to the map.
Both versions have the following file types: cpg, dbf, prj, qpj, shp, shx.
The file that is successfully adding to the map also has an shp.xml file, while the other file does not. I suspect that is the reason and perhaps I may just need to figure out how I generate that file type. I can't recall but I may have done it within ArcGIS by first exporting my shapefile to a geodatabase. I could be wrong but I vaguely remember doing something like with the older file in a random attempt to get this to work. We'll see how it goes.
Rename the *.xml to *.xmlold. and try switching up the order that you are adding the files.
I also assume that both shapefiles have a different name...if they don't that can cause an issue as well
DarrinNielsen
I have figured out the problem now but don't know how to solve.
I started with a clean file in QGIS that was clean and accepted by ArcGIS. This file had some multipart polygons, which I wanted to split into single polygons, so I ran that function in QGIS. This is the souce of the problem. ArcGIS would not recognize the file once I split the multiparts to single polygons. I'm not sure if there are some setting I would need to adjust to get ArcGIS to accept the new file or perhaps there is a function in ArcGIS to do the same.
Darrin
