I can't use SQL in my ArcGIS pro
8271
16
06-24-2019 02:43 AM
AliAzzouhri1
Can anyone help me?  way I can't use SQL in my ArcGIS pro, they always show me this message
DanPatterson_Retired
To calculate strings to text or character fields, on the dialog box, the string must use double quotation marks ("string"), or in scripting, the string using double quotation marks must also be encapsulated in single quotation marks ('"string"').
https://pro.arcgis.com/en/pro-app/tool-reference/data-management/calculate-field.htm
AliAzzouhri1
I tray with all types of data but still das not work...
did you try Python 3, and check the expression with the check mark
DaveBarrett2
It looks like  your features are in a shapefile?
SQL is not supported as an input method for Shapefiles, if you select the green tick a tthe bottom of your expression it should valiate it and warn that SQL is only supported for feature services.
Cheers
Dave
Asrujit_SenGupta
Using a Shapefile, should throw an error as below:
DaveBarrett2
Apologies, I was infering frm the FID field rathe tha OBJECTID, I an this alter on a Shapefile and go  error above. I also got an error stating it needed to be a feature service t use SQL.
Dave
KoryKramer
Esri Esteemed Contributor
Why do we think this is a shapefile - did I miss something?  I would guess that the input is an Excel table (field is Field 1) - ArcGIS cannot directly edit (i.e. calculate a field) Excel tables.
See https://pro.arcgis.com/en/pro-app/help/data/excel/work-with-excel-in-arcgis-pro.htm#ESRI_SECTION1_CF...
You could copy the table to a feature class in a geodatabase and then do the calculations you need.
Try Python 3
AliAzzouhri1
in ArcGIS pro, the SQL support just only enterprise GDB
