I can't seem to choose the reclassify method in the reclassify tool. It only allows me to use equal intervals not quantile or others. What am I doing wrong?
Hi Ian,
What if you go to the layer's Symbology first and choose the classification method there; then open the Reclassify tool? I believe it will work based on the public explanation provided on this equivalency issue noted previously for ArcGIS Pro: https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDExNTEwNw==
Hi Kory, Thanks for the comment. I saw that post but unfortunately that techniques does not seem to work when you use it in model builder. Any other thoughts?
Have you reviewed this section: https://pro.arcgis.com/en/pro-app/tool-reference/spatial-analyst/reclassify.htm
