I am facing installation problem of Arc Gis pro. " Installation Package is not supported by this processor type contact your product vendor" where as my cmputer prcessor is Intel Core i5 2540M CPU @2.6 GHz . Kindly help me.
3457
09-04-2015 11:30 PM
AliRaza1
DanPatterson_Retired
here is the list
http://pro.arcgis.com/en/pro-app/get-started/arcgis-pro-system-requirements.htm
if it isn't on it, then the message is valid
DEWright_CA
You also need to look a the version of Windows you are running; you need to be 64bit.
LaureneKoman
You must be installing on a 32 bit operating system. ArcGIS Pro can only be installed on 64 bit operating systems.
