Hyperlink in Popup doesn't open
764
02-01-2023 09:26 AM
Laura
by MVP Regular Contributor
My hyperlink will take me to the desired path in the attribute table, but does nothing in the popup inside of Pro.
When I hover over the path it shows a different path than what is listed in the popup. The paths are to local drives.
Robert_LeClair
Esri Esteemed Contributor
Laura - I believe you can do this by following the workflow seen here in the Use hyperlinks in pop-ups help page.  Hope this helps!
