Hi Joshua,
Did you ever figure out the issue? I'm running into a similar issue unfortunately.
best,
Michael
My application is also crashing when I attempt to run the Import Contingent Values tool. And now any effort I make to reproduce the table into a test/production table also crashes the application.
Turned out my application was crashing because I needed to address some data hygiene issues in my CSVs. The trouble was not related to the absence of subtypes...
Hi @JoshuaLogsdon1 - I am trying the same thing and I have only made small progress so far.
I see you have mentioned that you're not using a subtype, I'd still suggest having the subtype and subtype_name. Use the value "0" for the subtype and leave the subtype_name blank. Do you have the CV_TYPE2 and so on for the other domains? With the above importing contingent values was successful, however, got an error "Found contingent value error for field group" and was not able to save it.
have a nice day, I also dealt with this error for a long time, and finally I solved the problem with my own logic. The mistake we made here is that we enter a text value under the "CV_Value" column. What should be done is to give a single code to the repeating values, as we did when creating a domain. ıt will be better understood in the example image.
Oh my goodness you have saved me!!!! Your comment matches the contingent csv form set up here: https://www.esri.com/arcgis-blog/products/arcgis-pro/data-management/how-to-import-contingent-values...
