How to turn off layer blending
1769
07-02-2024 03:42 AM
BarbaraSchneider2
I'm using ArcGIS Pro 3.3.1. There are two polygon layers in my map. For both of them, layer blending is set to normal, but they still blend with each other. I want to turn it off! How can I achieve this?
Thank you,
Barbara
Tags (3)
DanPatterson
MVP Esteemed Contributor
It was a bug prior to 3.1.  In a pinch, try removing and readding the layers if a refresh doesn't work
... sort of retired...
BarbaraSchneider2
I'm using 3.3.1 and I notice it for the first time. Removing and readding the layer or refreshing the view doesn't work.
BarbaraSchneider2
I've just found out that this only happens if the upper layer has been generated by a buffer gp tool (Multiple Ring Buffer).
