I am trying to create a new feature on a hosted feature layer but am receiving the error "Value Type is incompatible with field type" for a field named "DatePutInService". This fields data type is set to date. I believe the problem is because when editing the properties of the new feature to be made the "DatePutInService" field auto populate in a mm/dd/yyyy 12:00 format while all the existing entries are in the mm/dd/yyyy with no timestamp. How do I stop ArcGIS Pro from auto populating a timestamp in the date field and are there any work arounds?
