How to split annotation by line or polygon?
1681
06-01-2021 02:25 AM
anyry
Is it possible to divide an annotation feature class elements in Arcgis Pro (using ArcPy) by a line or polygon into several parts?
DanPatterson
MVP Esteemed Contributor
If you mean through arcpy and not calling some tool from the geoprocessing tools, you will have to look at the available methods in the geometry you are interested in.  There are "cut", "intersect", "clip" and a variety of methods for geometries.
Whether they apply to annotation feature classes is another issue, since there is no particular case for that in the arcpy tree
Polygon—ArcGIS Pro | Documentation
... sort of retired...
Tags (1)
anyry
I tried the use of geometries and some geoprocessing tools (Erase, Clip, Split, Intersect), but none of the them work for the annotation feature class.
