How to split a polygon that intersects a line
1606
02-27-2025 09:25 AM
SanchezNuñez
Good afternoon,
I am looking for a way to split a polygon (a circle buffer) that intersects a line (a major road) and remove the part is outside, or on the other side of the road.
Any sample in ArcPy and Python?
Thanks
clt_cabq
Use the split tool from the editor Modify tool bar - you can use a line you construct, snapped to your road, or select the road centerline and use that to split your polygon.
JoseSanchez
Thank you @clt_cabq
I am looking for a geoprocessing tool, I do have more that 44,00 circles to process.
JMutunga
@SanchezNuñez can you also try the 'Preserve' method for Clip tool?
JoseSanchez
Godo morning,
This is how I did it:
  • Create 500 feet buffer
  • dissolve line layer by street class
  • for each 500 feet budder
    • create a 50 feet buffer
    • clip line layer
    • feature to poly to split 500 feet buffer at the line intersection
    • remove poly that is not intersecting the point
