How to shade area between 2 circle polylines
3539
12-24-2023 12:52 PM
ecorf
I'm using ArcGIS Pro 3.2.1 on my desktop. I want to create a few maps with 2 circles drawn from various distances from the center source.  In this example, 0.50 miles and 0.75 miles from the source.  I have a circle for each distance.  Each circle is a layered polyline.  Is there a way to color shade the area between the two circles to further highlight this area?
DanPatterson
MVP Esteemed Contributor
use a multiring buffer around a center point
Multiple Ring Buffer (Analysis)—ArcGIS Pro | Documentation
... sort of retired...
DanPatterson
ecorf
Thanks Dan!  That got me closer to what I was looking for.  I can't get that inner circle to be clear, the same color as the map - because the outer layer color always bleeds through.  But, this will probably be workable.  Thanks again.
ecorf
I was able to manipulate the colors a bit to make it very close.  This should work fine.  Once again.  I appreciate it.   I made the outer ring hex color: 0064FF 92% transparency and the inner ring hex color: FFEBBE 70% transparency and that made the inner ring mostly match up with the map background.  Big Thumbs Up!  Thanks again!
