How to reverse an Intersect tool?
6151
03-27-2022 09:52 PM
Hayley
I am building a model in ModelBuilder and need to select properties inside a boundary and properties outside a boundary.
The Select by Location tool is not giving me want I need so I have used the Intersect tool to pick up properties within a boundary.
What is the tool/how do I perform the reverse action of the Intersect tool so I can select properties outside of my boundary?
HL
LongDinh
Hi @Hayley ,
Have you tried the invert spatial relationship parameter on the Select By Location tool ?
The alternative is to use Erase after your Intersect on the original properties with the intersected data which will Erase the intersection from the original properties to create a new set - an inverse feature class
LongDinh
Hi @Hayley ,
Hayley
Yup the Select by Location isn't giving me the results I need which is why I'm using the Intersect
Thanks, great idea about the Erase!
HL
