How to return unique values from the field/column of table fgdB which participates in the relationship 1:M? I need unique values for the related report. Distinct keyword in Arcade does not do this on field/column (only on array, tested), and in SQL for file geodatabase this keyword is not supported!
Thanks for any help!
This goes back to my previous post
How you get the features variable depends on where you're using the Arcade code. It could be using the variable $datastore or $layer. Or you might need to get it from a function like FeatureSetByName or FeatureSetByPortalItem
What happens when you use "$datastore"?
Thanx! NOT PASS!
Regards!
That code should be
var features = FeatureSetByName($map, 'Kartirane geoloske jedinice', ['PreferisanaStarost'], true);
Distinct(features, 'PreferisanaStarost');
Thank you! Again problem!
