How to repair data sources for multiple layers in ArcGIS Pro
9631
6
04-12-2023 09:47 AM
BenjamenWetherill
I am finding that it is very cumbersome to repair data sources for multiple layers in ArcGIS Pro. For example, if you change the location of your files in your directory (as happens when you migrate to One-Drive or change any folder names), then you need to fix data sources for all layers in all maps. In ArcMap, it was possible to right-click on one broken layer and select Data-->Repair Data Source, and it would automatically repair all layers with the same relative path (but different data sources). This does not seem to be possible in ArcPro. It is necessary to do each layer individually, which can be a mammoth task if you have many maps each with many layers.  Why doesn't ArcPro provide this simple functionality?
Tags (1)
ZachBodenner
MVP Regular Contributor
It doesn't work quite as well, but try clicking the red exclamation instead of going Data-Repair Data Source.
Happy mapping,
- Zach
ZachBodenner
Happy mapping,
- Zach
BenjamenWetherill
That worked very well for me!  It never occurred to me to click there.  Thank you!
ZachBodenner
Took me a while to find it too. As much as I like ArcPro, for me this one falls into the category of "aint broke don't fix it." Seemed like the Data->Repair Data Source worked just fine.
Happy mapping,
- Zach
TimBohn
Not only is it faster one-time to correct, it did them all like that!!  Nice of you to post that!
V_StuartFoote
Functional steps in the Data Management blog by @HannahD  Hannah Deindorfer:
https://www.esri.com/arcgis-blog/products/data-management/data-management/arcgis-pro-tips-5-tips-for...
Use the "Change Data Source" in tip 5.
ScottTillotson1
Yes the help file on this one need to be very specific of here to click. Thanks so much for this.
