How to remove a character from Drawing order layer name using arcpy?
3100
7
08-01-2023 09:33 AM
Labels (3)
Davec43
I have a script that creates a geodatabase and then splits a layer by its name into that geodatabase. The problem is if the layer name starts with a number "123" it'll add a "t" to the beginning of the layer name. How do I strip the "t" from the drawing order using arcpy?
RichlandGIS
Unless you want to export them to shapefiles (which do allow filenames to start with numbers) you will run into that error.
You could use something like:
string = '_' + lyr.name[1:]
which would replace the 't' with and underscore which will allow you to save them in geodatabase.
R_
RichlandGIS
That is probably because you are not allowed to have geodatabase feature class name starting with a number.
R_
AngelaSchirck
Not exactly sure what you're trying to do, but to get rid of a leading t in python:
string = "t123abc"
newstring = string[1:]  //newstring will be everything but the first character of the original string
Davec43
Here's a snippet of a portion of the output. Since the layer starts with a number, arc adds a "T". I'm trying to script removal of all the "T's" since it can be tedious manually removing all of them.
When I try this:
import arcpy
Map_name = map1
aprx = arcpy.mp.ArcGISProject("CURRENT")
act_map = aprx.activeMap
map = aprx.listMaps(Map_name)
layer = act_map.listLayers()
for lyr in layer:
    string = lyr[1:]
I get:
File "<string>", line 8, in <module>
TypeError: 'Layer' object is not subscriptable
RichlandGIS
lyr is a Layer class, need to grab the layer name from it as string.  Think this is what you are looking for:
for lyr in layer:
    string = lyr.name[1:]
Though, you will still get an error if you try to save them with a name starting with a number in a geodatabase.
R_
Davec43
I see what you're saying. I found this from stack exchange and it'll strip the first character from Layer names if they don't have a number as their second character.
fcs = arcpy.ListFeatureClasses()
for fc in fcs:
    Arcpy.Rename_management(fc,fc[1:])
When I try it with a T123... I get
ERROR 000354: The name contains invalid characters
Failed to execute (Rename).
I'm assuming there isn't going to be a way around this?
RichlandGIS
R_
Davec43
Thats how I'll have to do it. Thanks!
