How to relocate multiple points by 0.1 miles along a line segment
1051
5
05-04-2023 06:37 PM
CTTrafficOps
How to relocate multiple points by 0.1 miles along a line segment? I don't know how to code so please provide tools that exist within Pro.
AndreasHall
You could create a 0.1 mile buffer around each point and then do an intersect with the line. This would however produce a lot of redundant point so you would need to figure out how to identify the redundant points somehow. Not sure if that is possible.
CTTrafficOps
Thank you for the response. Yes, the redundant points are something to figure out.
DanPatterson
MVP Esteemed Contributor
relocate in which direction?
... sort of retired...
CTTrafficOps
Different points go east, west, north, and south along highway routes.
MicZatorsky_AEC
Maybe linear referencing?
  • create routes from your lines using miles as your unit, the route calibrated to line length
  • get the m-value for your points using Locate Features Along Routes
  • in the resulting event table, calculate a new m-value by adding 0.1 of a mile to the current m-value
    • (think about what you'll do if it falls off the end of the line?)
  • use Make Route Event Layer to locate the points at the new m-value location
  • export the points to a feature class
