How to pass child record response from one child to the next, but to allow for edits?
504
01-17-2024 07:54 AM
NickAddison
The attached workflow is what I'm trying to achieve.
Right now I have it structured to pass the child-to-child and child-to-parent using the script below as a calculation constraint.
var relatedRecords = OrderBy(
    FeatureSetByRelationshipName($feature, "Hydrant_Data_Maintenance_Records_Relationship"), "Last_Maintenance_Date DES");
var relatedInfo = "";
if (Count(relatedRecords) > 0) {
    var latestRecord = First(relatedRecords);
    var conditionUpperBarrel = latestRecord.Condition_Upper_Barrel;
    // Check if the conditionUpperBarrel is not null or empty before assigning
    if (conditionUpperBarrel != null && conditionUpperBarrel != "") {
        relatedInfo = conditionUpperBarrel;
return relatedInfo;
This works in terms of passing the records from one to another, however, because it is a calculation, it doesn't allow for updates/edits to the child responses to indicate the change in condition status in response to the maintenance work performed. Am I thinking about this wrong? Should the child-to-child record passing, that is then editable, not be done via a calculation constraint?
Thanks in advance for any assistance!
